Not familiar with that particular car, but it should have a plug under the seat somewhere that will separate the seat wiring. If not, you may need to cut the wires, and rejoin them when reinstalling seat.
I suspect it's right above, but the early birds used single wires with bullet connectors on the wires and a coupling they plunged into. The wire colors should match, but if possible, make sure before you pull them. A different year motor with different color wires, after 50 years, don't trust anything.
If it's not to late, and you do find a junction block that you can pull wires from (ala my old tbirds) be sure to try to spray some lite wd40 or silcone spray in the area first.
It helps to keep from pulling the wire out the end fitting.
