1960 power steer cyl difference
41 rock
New member
what is the difference in cylinders, from 1960 to 61-62. Listing is 1960 by itself. Can I replace 1960 with a 1961 unit?
...what is the difference in cylinders, from 1960 to 61-62. Listing is 1960 by itself. Can I replace 1960 with a 1961 unit?
I cannot tell you the exact difference but there was a design upgrade in 1961. The drag-link and idler arm are also different.
Can yours be re-built?
considerably less cost than a 1960 unit.... is port size different , you suppose. both have the rubber eye, would think length be the same.
... considerably less cost than a 1960 unit.... is port size different , you suppose. both have the rubber eye, would think length be the same.
They are different. Look at the mounting differences -
1960 FORD 8CYL PS -
422859
1961/62 FORD PS -
422861
The power steering pressure hose is -- one year ONLY -- 1960 ONLY -- which I have listed on this website for (legally let you steal it from me at $ 30 !!!!!)
I also have rebuilding service on the power steering control valves.....
Always best to simply call me -- Craig -- 516 - 485 - 1935..... New York...
You know, I wish there was a site like this that would allow trusted small vendors not advertising per say, but a listing of trusted vendor(s) at a minimum that users have had good results with.
The big vendors are now selling CHI-COM one off junk/counterfeit and few realize it until it either doesn't fit or fails.
