Eighty6SVO
New member
Hello,
I recently came in to posession of an unfinished project 1959 Galaxie, and have been going through trying to inventory all the pieces, as the car is in pieces. So far, I think I have most everything, or have found a source for most parts except two. The first is the fuel filler cover/hinge assembly, but worst case that is something I can fabricate. The one I'm really stuck on is the lock assembly for the trunk. Attached is a picture with test fits of the trim, but I have nothing there. Just the latch, but nothing else. I've found one on Ebay, but it's NOS and over $400. I don't need an NOS one, and if the "zero" cover on it is missing, I could find a way to make one from the "zero" emblem I do have, so that's not even a big deal. Not being able to open the trunk from the outside is a bit bigger of an issue. Does anyone happen to know if there is any other source for the lock assembly? Or the other option, would be really good pictures and measurements so I can fabricate something until I get a real one? Or even a way to hack one together from other models would be fine.
Thanks for your help
