1959 292 core
streetdreams
Howell
Mich
Price
$1400 OBO
1959 292 core
Engine is complete, disassembled, checked and a good, rebuildable core.
Standard bore/ crank
113 big intake cylinder heads ( ECZ-G's with larger combustion chambers )
1.43 rockers
flat top EDB exhaust manifolds
manual bellhousing
flywheel, pressure plate core
2 barrel intake ( Autolite 2100 )
FORD script valve covers
This motor was pulled in the late '60s. Never reworked. Has original Ford bearings and hd gaskets.
Have a ECZ-B 4 bbl intake for $150 extra with motor.
No guessing or gambling on a core motor with this one. If you're thinking of updating your Y Block, this is a good starting point. My shop can also rebuild to your specs, and yes, I can do the oiling system mods, rework the rockers to full pressure lube and install cam bearings correctly.
