Good morning,
We have a 1957 thunderbird with 312 and holley 4 barrel in our shop. The fuel pump was leaking through the 2 holes on the side (I'm guessing its a bypass of sorts?), we got a new fuel pump from NAPA and sent the old one in for a core (Mistake)... put the new fuel pump on and it won't get gas up to the carb, it just starves the motor. We tried priming the pump and running the car for 2 minutes and it still will not get gas up to the carb.
We figured maybe its just a bad aftermarket pump, so got another fuel pump from carquest. Same results! Both pumps are installed correctly on the cam lobe. When we put them on the bench, they both have good vacuum and push out, but the arm has to have full travel in order to push air out... Is it possible that the arms are incorrect and not getting the travel needed to work properly?? We are kind of stumped right now, so hoping someone else has run into this and can shed some light on the situation. I really don't want to have to put a electric pump on just to get around this problem!
Thanks!!
Thanks!!
