1957 Ford tach drive distributor N.O.S.
Kemptville
Ont
Price
700.00
Genuine N.O.S '57 Ford tach drive distributor number FEK 12127 C2. Third digit is extremely difficult to read but is either a "K" or "H". Below these numbers are H 691 . Unit has been laying on a shelf for many years but is absolutely N.O.S. and has the original "fomoco" points, condenser and straight shaft vacuum advance unit. The drive gear appears to have been painted aluminum a long time ago. Asking $700.00 and will include shipping to Canada and the U.S.A.. For some reason I can't download the pics???? Call for info at 613-258-0336 (Canada) or email. Thanks : Bruce
Upon further investigation I have discovered that this tach drive distributor is actually for a 1957 Mercury 368 cu. in. motor. It has a 15 tooth dive gear and that is the only difference between it and one for a Y-block Ford or Merc 272-292-312 that uses a 14 tooth gear. It is N.O.S. and I have several pictures if you are interested. Thanks : Bruce
