1957 Ford front backing plate diagram
Steve in Denver
A friend is looking for a diagram of how the front backing plates should look for his '57 drop top. He thinks he has two right side backing plate assemblies.
Only thing I can think of is the adj. star wheel would be in wrong position compared to the adj. slot (reverse the adjuster). bet L & R are the same if they both fit
:eek:​
Both plates (L&R) are the same...
I did not know that. It explains a few things such as self-adjusters refit.
To further expound on the subject -
1954-56 FORD used L & R
1957-60 FORD used the same plate both sides
1961-64 FORD used L & R w Self-Adjusters Feature
You are more than welcome. If you don't mind, can you post his reaction to the news?
How many did I work on and it never dawned on me ... :confused:
You're smart ... ;)
I kept wondering why it was described as the adjuster being reversed on a SELF-ADJ SYSTEM being added ... :confused:
