1957 e-bird vacuum
Rhenders
New member
I was wondering if anyone can tell me the proper way to connect up the vacuum lines from the distributor to the (2) holly teapots on my 1957 t bird. Right now there is no vacuum line to either carb. The car is a 3 speed with an over drive. In addition, this t-bird appears to have the carburetors rotated 180 degrees from what I have seen in pictures, I was told that this was required in order to allow the air cleaner housing to clear the hood scoop.
Yes, the carbs on T-Birds are backwards compared to passenger cars. The vacuum to the distributor diaphragm goes to the rear carb only (I think). The front carb gets a threaded plug in the vacuum hole. The link below will have all of the correct lines for your car (vacuum and fuel).
Sal
http://www.classictbird.com/
Here is a photo(s) of the 57 H4000 ported vacuum source port-
The PASS CAR setup is shown but will detail the port location.
381459
381460
381461
EDIT -
While Carousing With My Browser, I came across this-
- 1957 BIRD E-CODE Right Side Shot -
381514
