1957 convertible top moulding clips
These clips fasten the stainless steel moulding at the front of the top (and cover the top fabric), They are 2 inches by 1 inch with the bolt centred in the clip - 8 are needed.
Where can I get them?
Andrew in Ontario
Do you see the MLDG in the ILL? Can you give me the PN and I will see if ATTACHING PARTS are cataloged.
Check with Concours Parts in Nevada. Tbirds use a clip that does the same thing. CASCO lists a kit as # 161 or 161A. They might be the same???
Still working on it. FORD deleted this info from their FINAL ISSUE MPC.
Does your setup consist of three pieces as shown in the ILL above?
Better yet, do you have a photo of one?
