Babyboomerboy
My windshield wipers in my 1956 Ford Fairlane don't work. Can someone give me some advice on where to start checking the system to find the problem? Thanks
I applied white lithium grease, and reassembled it. The only complaint I have is that in the winter time or during cold weather the dash has to warm up a little bit for the wipers to operate normally.
KULTULZ; 06 APR 2018 POST #6 said:You should consider having a Shop Manual.
First you establish the strength of manifold vacuum and if the vacuum signal is reaching the wiper motor. This also includes testing the vacuum signal from a two-stage fuel pump if so equipped.
-Improving Windshield Wiper Function-
-CLICK HERE- Windshield Wiper Vacuum Source -CLICK HERE-A Frequently Asked Question: How do I improve the function of my original Thunderbird windshield wipers?
Answer:
The most probable cause for Thunderbird windshield wipers not working properly is because they are not used regularly. After years of very little use the seals have dried out causing the wiper motor to be sluggish. The internal wiper motor seals need to be cleaned and lubricated. The procedure to do this is as follows
- Connect a clear bottle containing Dot 3 or 4 brake fluid to the inlet tube on the wiper motor located under the dash. I use a plastic bottle with a hole punched in the lid and a rubber vacuum hose that fits snugly on the wiper inlet tube. The wiper inlet tube is located on the side of the motor facing the radio.
- Turn on the wipers, run the engine at idle, turn the wipers and the vacuum should suck the fluid into the wiper motor.
- Then work the wipers by hand until they work on their own. The brake fluid will soften the dried leather seals in the motor.
- Make sure the vacuum hose is always below the level of the fluid. Also, to prevent blade drag on the dry windshield, squirt soapy water on the windshield, this will provide lubrication for the blades.
- It usually takes about a pint of brake fluid to complete the process. It’s a good idea to have an old rag or towel on the floor under the inlet to catch any drips once the fluid hose is removed.
- Run the wipers several minutes after the fluid hose is disconnected to remove excess fluid from the wiper motor. There will be some white smoke from the exhaust as the fluid is sucked into the engine. It will not hurt the engine and will clear up soon after all the fluid is purged from the system.
- Also, check to make sure that the vacuum source lines are connected correctly to the engine.
If this procedure fails to rectify the problem, the wiper motor must be removed and repaired or replaced.
For description and detailed photos see the article titled Windshield Wiper Vacuum Source under the “Body/Suspension/Steering” section.
4. After the rubber hose passes through the firewall under the dash it is connected to the top of the wiper motor port that points to the passenger side. The bottom port on the motor is an open vent and not a connection. A "T" fitting is installed in the hose which supplies vacuum to the heater vacuum control valve inside the metal heater chamber.
Yes, check for vacuum at the intake manifold source, it should be there...... I would try the intake manifold source first. The pump valve/diaphram may be stuck/frozen. Do you have a vacuum gauge (about $10 )
SOURCE- http://forums.y-blocksforever.com/Topic136157.aspxoldcarmark
Possibly another problem You may have is the wiper Pivots may be seized up from non use where the arms mount. You can disconnect them under the Dash where they hook onto the Motor Arm. Then you can run the Wiper Motor and see if that makes any difference as far as the motor working correctly. If that helps then You can try dripping some Penetrating or similar oil down the Pivots to free them up
What do you mean by “Make sure the vacuum hose is always below the level of the fluid.”. Do you mean the clear bottle with the hose connected to the input port on the motor needs to be above the motor? If so I guess that would mean up on the dash?
