1956 Ford F100 Big Window
fordtrk56
SoCal
Ca
Price
11500
1956 Ford F100 Big Window: One of the nicest original factory RUST FREE,straight cab, matching doors with all hardware plus SS window trim, good front/rear glass, wind wings, drive side exterior mirror, interior mirror, Chevy tilt column with billet dress up and mounting kit, fresh air heater w/cables, switch, mounting bracket and defrost deflector trim, good gas tank w/sender,filler neck with cap. All Fresh 351W/C4 trans with zero miles, Mallory electronic distributor, aluminum intake, Edelbrock 4bbl carb, aluminum valve covers, 4 wheel disc brakes with all new pads and hoses, Volarie IFS with new suspension parts, ball joints, bushings, shocks, etc., New Power rac/pinion steering and tie rod ends, Powder coated frame, front IFS and rear axle housing and running board brackets, NEW: front/rear rubber cab mounts and rear brackets, 12V wiper motor, harness, switch and bezels, 12V under dash, under hood, brake and taillight wire harness, painted tail lights with harness, 12V fuel and temp gauges, wiper pivot bezels, headlight switch with bezel, under cab power booster/master cylinder, steel brake lines with SS clamps and rubber hoses. NEW assembled bed, tailgate, hinges, chains, bed runners, oak wood kit and bolt kit still in shipping crate, front/rear passenger side fenders-still in original boxes, NOS LF fender, original no spare well LR needing a patch. Nicely upholstered cloth/vinyl seat, mounting bracket, dome lite, glove box door and insert, ash tray, original dual exterior door locks, emergency brake, radiator valance with hood latch, wind deflector panels, inner fender panels already cut, radiator core support, recondition radiator, mounted chrome front/rear bumpers, painted rear brackets, guage cluster, nice clean straight running boards with aluminum side trim molding attached. Rust Free, straight hood, all emblems, BMW tilt hood kit. Nice straight gravel pan and park lights. 2 piece aluminum drip rail trim. Many more pix available..
