V vance New member Nov 13, 2011 #1 I need help to find out what is making my 56 ford surg while idleing it is a 292 motor any help many thanks vance
all american boy Well-known member Nov 13, 2011 #2 vance usually vacuum leaks in lines or gizmos connected to carb cap all vacuum taps on carb and see if it improves that's a vacuum tap sticking out of front metering block Attachments Holley O-9776.jpg 9.6 KB · Views: 4
oldbugger Well-known member Nov 13, 2011 #3 Spray a little starting fluid around the flanges where the intake connects to the head, if the motor changes speed you found your leak. Good luck
