1956 Country Sedan Window Regulator Question.
'56LongRoof
I have a ‘56 Country Sedan that is in need of all 4 window regulators. I’m assuming that the window regulators out of the front of any ‘56 2 or 4 door model would work and the rear regulators out of any ‘56 4 door models would work for the Country Sedan. Any idea if my assumption is correct? Also, does anyone know if other model year regulators work in the ‘56?
YOU MIGHT - file:///C:/Users/My%20Pc/Downloads/Window%20Regulator%20Restoration-Danchuk.pdf
(Insert ADDY In Your Browser)
Thank you! But there is a difference between the front and rear, correct?
It does not differentiate between them other the man/electric. Both 2dr and 4dr have same part number B5A7023206A-7A. It does show 4dr Victoria as being different in the rear with part number B6A5727000A-1A.
I have two parts cars I can see if regulators are still good on. One is a 55 mercury 4 door sedan the other is a 56 Mercury wagon. Cars are not at my house so not sure when I can check condition.
The window regulators are multi-piece.
ILL's are attached. You will most likely have to remove the interior panels to diagnose exactly what you need. You will also need a 56 FORD WORKSHOP MANUAL.
Your BODY TYPE CODE is 79 (4DR SW).
NOTE - Of course they do not show large enough to read. Maybe try to print or I can E-MAIL them to you.
Yeah, I have the manual and I have removed, semi restored one rear regulator so I am familiar with the procedure I was mainly wondering about which model years would be interchangeable..
