39deluxecp
Can anyone tell me what radial tire size they are using on their 1955 Tbird? I want to be sure they will clear the body. Thanks
My 55 Fairlane has 14" wire wheels with the Thunderbird logo in the center. I've been wondering if they were really Thunderbird wheels or not, wish they were 15" only thing bad is I just put Coker wide whites on and can't afford to buy new wheels and tires.
Yes.As far as the early Birds (55-57), they did not have a true wire wheel. The 55 and 56 had a wire wheel type hubcap setup.
The first Ford true wire wheel as standard or optional equipment came out in 62-64 (not sure of the exact years). Don't know if they were 14 or 15. Kelsey-Hayes made them.
Apparently the tubes (or tires?) available back then were failing from the extra heat.What were ventilated tires, mine has tubes, but never heard of the ventilated term.
99% chance they're newer reproductions. If 'original' to '62 / '63 they would most likely be in need of a complete re$$$toration (if that's even possible) also have 48 spokes and most likely stamped with K-H and FoMoCo logos. Worth a lot of money to some collector tho...My 55 Fairlane has 14" wire wheels with the Thunderbird logo in the center. I've been wondering if they were really Thunderbird wheels or not, wish they were 15" only thing bad is I just put Coker wide whites on and can't afford to buy new wheels and tires.
I've been toldI just read the information about the wire wheels. The change they made was the dia. of the spokes, not the no. they changed the dia. from 1/4" to 5/16" I've got to check mine. Thanks for the info. Al
I didn't count the spokes, just measured them. They are 1/4", but I did see one of them without the tire installed. I looked to see if it had a rubber cover over the spokes, it did not, there was what looked like a stainless band around the center section covering the spoke ends. I'm trying to find out who made them. I know there are several companies that offer them, and there are 3 different spoke arrangements. Truespoke has 50 spokes attached at the center of the rim, and a reverse 50 spoke wheel. there is a lip lace style and a standard style, I took pics and have to go back and see which I have.[/QU.OTE]
I have counted the spokes on my 14" Thunderbird rims, they have 56 spokesw and are made by Tru=Spoke. Talked to them this AM sent them pic. of wheel, the man said it was a wheel they make. he didn't know about the S.S cover over the inside spoke nuts, said someone had added that after wheels were sold. He also told me if I was driving and got caught in rain to use Pledge furniture polish on the rims until they could be cleaned properly. He also said if car was to be in storage for a lengthy period to spray them with WD-40. He also told me to check for loose or broken spokes with a plastic screwdriver handle and listen for a spoke that sounded different. Mine are the lip laced wheels.Al
just curious... what wheels did you use?I got a set of 4 ties in it.205/60/15 size, and they look great and fit perfectly. About an inch clearance between rear tire and rear fender . Thanks for all the help
205/75R15 - assuming original 5 inch wide wheels.
They'll clear the fender skirts by about 1/2 to 5/8 inch.
(depending on conditions of the individual car)
The original tires were 6.70 x 15
http://automotivemileposts.com/tbird/prod1955tbird.html
