poolplayer1
This morning I did some voltage testing on the ballast resistor. With the ignition switch to on, I get 11.9 volts on one end of the resistor and 5.7v.on the other end.This is the end that connects to the + side of the coil. With the engine running,I get 10.4v on the + side of the coil, not the 5.7v.
Is this too much? I think you mention that it should have about 8 or 9 volts.
The resistor measures 2 ohms.
There are only 2 wires coming off the ign.switch that would have any affect on the ignition system which are the yellow wire going to the starter solenoid and the one going to one side of the ballast resistor. The others I think would not have anything to do with the engine shutting down.I am thinking about replacing both of those wires.
I think 12 gauge wires would be fine.What do you think?
Thanks again.
Thanks again.
