zoegrant
How do I determine what 2 barrel carburetor CFM ford used in 1955 on a 3 speed standard shift sedan ? The carb on the car is stamped Ford and is the Stromberg type two barrel, with a 3 hole base.
I am trying to determine what PCV valve I should use when installing a PCV system on my 55 sedan.
Also, if I install the PCV system in the valve cover instead of the valley pan cover would that work as good as if had installed it in the valley ????
