I am building a 55 ford 1/2 ton pickup. I have a corvette power rack suspension. The rack is mounted in front of the cross member. I am going to install a 74 302 engine. The question is seeing the rack is in front of the cross member I will need a rear sump oil pan. Will a late model duel sump pan work or should I use a bronco rear sump pan? Any suggestions. Thanks Jack
