O old31 Well-known member Oct 21, 2023 #1 How do you get into the trunk when the key does not work? When I turn the key, the key keeps spinning, as if nothing is nothing is behind the lock. Previously the lock worked properly.
GLAmes Senior Member Oct 21, 2023 #2 You might have to remove the rear seat back and find a person who is small and agile to crawl in to release the lock.
Ford blue blood Well-known member Oct 21, 2023 #3 With the rear seat removed get a bunch of extensions and remove the catch, two 1/2 " bolts if I remember correctly.
O old31 Well-known member Oct 21, 2023 #4 Fixed! Removed the seats, tried to crawl in the trunk hole, sucked in my gut to make the hole, and then connected the key lock mechanism. Not fun. Last edited: Oct 22, 2023
