The parts book I use for my '55 says 13 lbs, and also has another 'replacement' at 7 lbs.
The increased pressure raises the boiling point slightly and helps if the engine runs toward the hot side, a bit less likely to boil over. If the cooling system could be in better shape a lower cap pressure can postpone some leaks.
