Motorhead6
My '55 sedan has perfect brakes. Assuming you did the proper adjusting and bleeding, the first thing I would check is that you have the correct wheel cylinder and master cylinder bore diameters installed. A larger MC (less psi for a given pedal pressure due to a larger piston area) or smaller wheel cylinder diameter (less total area of the piston face and thus less total pressure for a given pedal pressure) will reduce braking performance. Over the years someone may have installed the wrong parts.
An improperly arched set of shoes should not significantly affect stopping power, but will require more frequent adjusting of brakes until the shoes wear into the drums.
