bigdaddy3
Ok, so I've got the Aerostar springs and Kyb shocks ready to go on. I've got the shocks off so far.
I've consulted the 1955 Ford Service Manual. It talks about using a special tool to remove the ball joints to replace the springs. Is there an easier/better way without messing with the ball joints?
Also, I know I need to replace the bushings on the lower arm as well as the upper arm. Everything I've read so far says replace the shafts, bushings, washers and nuts. Everything related.
Joblot has a kit to replace both upper and lower for $115. Attached.
Also, the bushings and end links for the stabilizer bar will be replaced.
What else while I'm under the front end doing suspension?
Please and thank you in advance.
