1955 Ford Fairlane parts
Blue Moon
Santa Clarita
California
Price
in ad
**** Read..... I will not answer Text or Emails asking if parts are still for sale. If ad is up, stuff is still for Sale.
1955 Ford Fairlane, 55 Ford, Y-Block, Ford-O-Matic.
Some parts have been blasted with glass bead.
Parts are off a 1955 Ford Fairlane, 272 Ford Y-Block
Pick-Up in Santa Clarita, Valencia
call 818-266-3540
**1955 Ford V8 272 Y-Block what you see is whats for sale, car was not running when i bought it.
I have an engine hoist to help you load it....$100.00
*** Stand is not for sale....
**Ford 272 Y-block exhaust manifold headers...$100.00
**1955 Ford Parking Light Housing (Left & Right)...$50.00
These are originals taken off of a 1955 Ford. The insides of the housings has some surface rust and they have a few dings and minor scuffs.
**Ford steel wheel 15" has K-H stamped on wheel. (only 1) $25.00
**1955 Ford Ford-o-Matic, from a 1955 Ford Fairlane w/V8 272 what you see is whats for sale, car was not running when i bought it...$100.00
**1955 Ford Ford-o-Matic, rebuilt Torque Converter from a 1955 Ford Fairlane w/V8 272...$100.00
**1955 Ford passenger car front splash pan, Surface rust only, good shape...$200.00
**1955 272 y block timing pointer...$20.00
**1955 272 y block Oil Vent, Draft Tube...$20.00
**1955 272 Y Block Ford oil pan front sump...$75.00
**1955 272 y block Original Used Steel Vintage Valve Covers, no dents, surface rust only...$20.00
**1955 FORD Y-BLOCK 2V CARBURETOR INTAKE THROTTLE BELLCRANK...$20.00
**1955 Original accelerator linkage rod used on 1955 with a 272, Y block V8 engine and automatic transmission...$20.00
**1955 272 Ford Y block front mount plate...$40.00
**1955 grill center piece, small ding, Straight, No pitting, Good chrome...$20.00
**1955 FORD Y BLOCK 272 V8 GENERATOR BRACKETS...$20.00
**1955 Ford Fordomatic Air Vent cover...$20.00
**1955 272 Ford Y Block Valley Pan Valley Cover...$20.00
**1955 Y Block Flex Plate, ford-o-matic...$20.00
**1955 Ford 272 y block crankshaft balancer...$40.00
**1955 FORD 272 y block V8 TIMING CHAIN COVER...$40.00
**1955 Ford original accelerator shaft to engine support hanger, 272 V8 auto...$20.00
**1955 Ford 272 Y-Block Cast Iron Oil Pump, (needs gaskets)...$40.00
**1955 Ford 272 Y BLOCK INTAKE MANIFOLD...$40.00
**1955 Ford 272 y block sump and pick-up tube (some small pin holes.)...$40.00
**1955 Ford 272 y block oil cap original, (some small pin holes.)...$20.00
**1955 Ford 272 Y-Block Water Pump Pulley...$20.00
**1955 Ford 272 y block Fuel Lines to carb...$20.00
**1955 Ford 272 Y-Block Fan Blade...$20.00
**1955 Ford 272 y block Engine Motor Mount Support Front Steady Rest...$20.00
**1955 Ford 6v battery tray...$20.00
**1955 Ford-O-Matic dipstick and tube...$30.00
**1955 FORDOMATIC FLEX PLATE starter gear to torque converter Needs new gear, has wear...$20.00
**1955 Ford-o-matic small cover to converter housing...$10.00
**1955 Ford-o-matic cover to converter housing...$10.00
**1955 2 barrel carburetor Ford 272 y block, Original Ford part EBU-1...$20.00
Clink on link to view photos, they're not in order so if you have any questions please send me a PM
http://s1250.photobucket.com/user/55fordtownsedan/library/
