1955 272 V8 dipstick lengths
tailfins
i'm trying to determine if I have the correct dipsticks..can anyone tell me what the correct lengths should be for oil and txmn sticks?
any diff from 272 and 312"?
thanks very much
My 272 oil dipstick measures 21 1/8" from under the handle cup to the tip.Can't help you on the trans. as mine is a manual . Mine is the side of the block location.
I don't think oil dipstick length is based on engine displacement. The length is more likely different depending on which dipstick location the engine is using, for a front sump or rear sump oil pan. Two of the more common locations are on the block... photos below.
I've got a '55 292 and a '58 312, the oil dipstick on both measures 25 & 1/2 inches from the tip to the top inside of the cap. Both engines have the dipstick tube halfway back on the right hand side of the block for a rear sump pan. (used by pickup trucks & T-birds)
I have two dipsticks for the air-cooled '55 Fordomatic behind the 292. The one in the car has had a minor repair where the cap attaches, it measures 22 & 3/4 inches from the tip to the top inside of the cap. On a shelf is a spare transmission dipstick that didn't need repair, it measures 22 & 5/8 inches tip to top inside of the cap.
