JMFL36
Hi guys. I'm trying to sort out the distributor on my '54 Mercury Monterey. The car was running fine prior to pulling it for a rebuild. The first thing I noticed was a broken tooth on the drive gear. Second, the gear is a 14 tooth gear, where my shop manual calls for an 11 tooth gear?!? When I pulled the gear off, I found that someone had drilled a 2nd hole through the shaft?!? The distributor body has the correct part number FAE-12127-C for the car. Any suggestions as to what is going on? Should I just find another 14 tooth gear and install it in the added shaft hole? I'd like to make it 'right'.
