It would be like using any other non stock rear end, measure the width, reset the spring perches, getting the right angle, then there's the gear ratio to take into consideration.
I used an explorer rear under my wagon as I put 4 wheel disks locar makes a cable kit for the explorer emergency clevis also make sure you get the flange from the driveshaft as the coupling bolts together you have to change the spring perch replacement are available at any race parts supplier {summit speedway ect} also get the lower mount you will need to get new u bolts and fab a shock extension you can use the stock shocks check the pinion bearing as well as axle bearings as I speak from experience good luck
