1954 Ford Sedan Delivery
If you are going to keep the stock rear you can use a 1982-86 Crown Vic drive shaft ( Mine came from a 1986) change the rear u-joint to this: NAPA part Perfection 506 this drive shaft will have the correct yoke for both C4 & AOD's.
