rotorwrench
This was already mentioned but a good dose of anti-seize on the centering journals should do the trick. I use the nickel based stuff but any anti-seize is better than none.
Could removing the distributor every time the points were changed also help prevent the dissimilar metals from fusing together?
Is the car still 6 volt positive ground, or was it converted to 12 volt negative ground?Thanks for all the info, new question. Anyone running Pertronix in a 239 Y blockwith a generator ? Some of my fellow flathead friends have had problems they say caused by the generator. Pertronix happier with an alternator?? Thanks in advance.!!!!
