Mikko_
I have some issues with the stock Holley/Ford 94 on my '53 Customline.
When it sits for more than a day I need to prime it with some gas to start it, same thing when it has been driven a longer distance and is warmed up.
This seems pretty strange to me since I'm running an electric fuel pump, no matter how long I let it pump before I crank it, it just won't start.
But if I drive it and let it sit for just an hour or two it starts fine.
Also, my oil smells of gasoline so I suspect the power valve is leaking.
Since the carb has been pretty butchered over the years with threads destroyed and oversized screws put in to solve the problem I'm thinking of getting another carb in better condition.
Should I go with one of the new Holley 94's available?
Or go with something like a new Stromberg 97 or even a 4bbl carb?
The last 2 will also require another distributor than the stock Loadamatic as I understand it.
What would you do if you were in my situation?
I want to have a somewhat reliable car to enjoy
