Don't be surprised if you find out that it won't fit a Mercury.Thank ya. Been searching forever and ain't found one. Wasn't looking in the right place I reckon
The correct part number for the harness is 1M-14486A and C&G has it at this link > http://cgfordparts.com/ufolder/fordpart.php?number=1M-14486A
Also, I found this > http://www.egmcartech.com/store/Nos...Turn-Signal-Switch-Monterey_401005314766.html
109 dollars. Wow. I would mak a mount for this one before that. Thank you though!
Well, at least you now have the correct part number....
I fixed a malfunctioning slide switch by removing the back and appropriately cleaning and lubricating it as required with dielectric grease.Before I spend a $109 on nos parts let me ask yall this. I might could fix the one I have. We plugged a flasher into and it started smoking out of the column if I'm not mistaken (I wasn't there another man was working on it) the turn signals were working for a couple seconds before it started smoking. Now we aren't getting fire from any of the uhh 7? (Is that right) wires from the column. I was told that the only thing to do is replace or pull it and was hoping switch was reproduced.
There should be a center cap that either twists or is pried off (try twisting first).How hard is it to pull the horn and steering wheel on these cars without wrecking it? I'd like signlal lights on my Merc but don't dare try removing the wheel without knowing what I am getting into.
Once you have access inside then remove the center nut. Then using a wheel puller and the two 5/16" bolt holes, remove the wheel. The horn ring comes off with the wheel.
