D Doug26T Junior Member May 16, 2016 #1 I'm new to the late flathead models. The battery was out of the car when I got to it. Is a 53 positive or negative ground? Thank you
D Doug26T Junior Member May 16, 2016 #3 Thanks I thought it was, but I wanted to be sure. I have a T and they are negative ground, I know A's are positive ground. When did they go to Negative ground?
JSeery Member Emeritus May 16, 2016 #5 When they switched to 12 volt batteries. Have you looked at the 1953 Ford wiring diagram? Attachments Flathead_Electrical_wiring1953.jpg 79.3 KB · Views: 21 Last edited: May 16, 2016
D Doug26T Junior Member May 16, 2016 #6 Thanks - I saw that on the schematic - I just wanted to be double sure before I boogered a new battery, or old generator
