Ronnieroadster
Would anyone know if a center sump oil pan on a flathead V-8 fit in a 1953 Ford F-1 without hitting anything? Usually the rear sump pan with the removable lower plate to clean the oil pump screen is used in the F-1 from 1948 to 1952 but with the change in the 53 truck design the oil pan I think is different.
