S sanford Member Sep 22, 2020 #1 I recently acquired a 1953 Ford sedan. How does one check the differential gear oil level? I cannot see a plug to do that, only a plug at the very bottom for draining the oil.
big job Well-known member Sep 23, 2020 #2 Plug is located on the passenger side of the nest some call pumpkin a 3/8 ratchet will remove the plug which is a recessed 3/8 square plug............
