Ardun
- City
- Reno
- State
- Nevada
- Price
- Various
For local pickup or will drop off to your local shipping/packaging depot. All parts in good condition, cleaned or original From my '53 Ford Customline. Removed all to put in an V8 & AOD Transmission.
1952-1954 Ford V8 or 6 cylinder 3 speed overdrive transmission, 12 volt solenoid, wiring harness, t-handle cable, accelerator kickdown switch and aftermarket 12 volt relay $225.
1952-1953 Ford V8 Bellhousing complete with bottom pan, front pan throw out arm and seals. $150
Ford 8ba Balanced Flywheel, 10" clutch, throw out bearing, pilot bearing & ARP bolts $175
Clutch linkage, brackets & shift rods $175
1953 Ford 6 Cylinder Engine complete and attached to the original 3 speed transmission. 75,000 miles. Well cared for and clean. Runs very good, not an oil burner. Took out to install a V8. $750
1952-1953 Ford 6 Cylinder Radiator. Good condition. $115
6 cyl radiator support tie bar $25
Will accept offer for all parts.
Tom. (775)901-5118
Tom. (775)901-5118
