1953, 215ci rebuild help
tz5dv9
Hi guys, I was wondering if I could get some suggestions for good parts suppliers. I am rebuilding my 1953, 215ci inline 6 cylinder engine for my truck. I need rings, gasket set, main brgs, rod brgs ect.. any help would be appreciated. Thanks
215/223 gaskets and bearings are available from most of the big parts warehouses.
Rings for the smaller 215 should be available the pistons are not.
Hi; Think about a '54 up 223 six... Just a bit longer I believe [ 1/2"], and used thru '64 Newc
Thanks guys, I just inherited this truck. I have done a lot of body work in the past but never rebuilt a motor. This will be my first attempt. Could you please provide the actual names of trusted suppliers.
I used a local shop when I rebuilt the 215 in my 53 Courier. This shop is in the Parts Plus network. They provided all the parts and did the machine work. The 215/223 is pretty common. So parts should not be hard to get. Look for a jobber that has been in business a long time, like 4 or 6 decades.
A local parts store ?? Nice to have an actual person to assist you...
Otherwise there are re-ring kits online from Clegg and falcon.
While you´re at it give the oiling of the rockers some attention it´s a weak spot on that engine.
If you have an operation like this in your area use them.
http://sanelautoparts.net/about/what-make-us-unique/
The machine shop crew here knows their stuff. This is not your typical parts store.
Like flatheadmurre says oiling is an issue. I had the block cleaned and checked for cracks when i did mine. There is only one supply line to the rocker shaft. Make sure it is clean and not kinked. Where it is pushed into the block under the side cover make sure the rubber sleeve is fully seated. Check the flow by manually spinning the oil pump.
Try Bob Selzan @ Half Ton Fun in NJ 732 928 9421 closed wed. Sat. & Sun.
He had everything for my 48 six cyl. & almost all NOS Ford.
Good luck , let us know how you get on .
Cheers
Tony
tz5dv9,
I have a complete 215 out of a '52 Customline that ran good when removed with 52K original miles. Has trans clutch and bell housing. Also has air cleaner, carb, generator, starter and fan. I am also in Michigan (Shelby Township) northeast of Detroit. If interested in the engine/trans, send me a PM with you're email address, and I can send pictures.
Sal
41Ford1, are you using the Sanel's in Concord or Manchester? Good to know they are pros. I buy the paint for my shop from them.
I have some NOS engine parts for your motor. Probably less than half what most suppliers ask. Let me know when you find out what oversizes you need.
