1952 ford customline horn
tonydennisadw
tired of trying to get this to work advice please i take horn push bar off pull wire from center touch on side of metal horn works fine.....take aluminum part that is push and turn to get off cleaned everything i can see put back on and works some ties pushing in a certian area this is not the center area push button type but the alum frame type th goes over the wheel... ive looked everywhere to fine a parts showing going togeather.. but positive im putting back correct... somthing must need bent somewhere tks Dennis
I had this on my 50, clean the steering wheel contact area that the center horn chrome touches. You may need to sand it to get solid contact.
