mattrat31
Hey guys, I've got a 1931 sedan with a 52 flathead in it and don't have any oil pressure. I know that oil is running through the system because my stock oil canister is filled with oil. I've got my oil pressure sender at the bottom of the block using a pipe thread T. From there the oil goes through 1/4 inch brake line into the bottom of the canister and then out using 1/4 inch brake line into the back of the block by the fuel pump.
So I know that I have oil flow but my modern stewart warner gauge is only reading maybe 1psi. I need your suggestions and what I should do. Thanks.
