1952 F-1 odometer
ken-r-mer
Just came across an interesting issue. While my speedometer works just fine, the odometer stopped working. Can it be a bad gear tooth? Are parts availalble to fix it?
Could be the "button" is not pushed all the way in or pulled all the way out, I forget which is which. Give it a try.
Button? Nothing showing on the front glass bezel. This is a truck F-1 Speedometer/odometer. No trip meter if that is what you are referring to.
my guess like yours the gear is stripped, they are plastic ,, get a hemmings magazine and look in it for speedo rebuilders, some one will come along after awhile and be able to give you more specific info
