What it all comes down to on the self adjusters is to find a later model Ford that uses the same brake shoes then you use the same hardware and adjuster kits. The first one we did in the Group was the 1952-54 Fords they use the same shoes as 1967-72 Mustangs so that made it easy.
One little trick is to use the Rock Auto catalog online when you click on a brake shoe part number you get a pop up showing other cars that use the same shoes self adjusters became more standard about 1962 and later.
You match the aduster and hardware kits to the shoes 10" to 10" and 11 " to " 11 taking also the width into account as well. This has become an issue with most 1955-59 Fords as finding drums and shoes for these has become a nightmare for many check out the link here: https://www.rockauto.com/en/catalog...+v8,1435194,brake+&+wheel+hub,brake+shoe,1688 Notice that a lot of the cars in the list are pre-60's that did not use self adjusters.The 1957-59 Ford 9" rear ends have been in demand for swaps for years in 50's Fords and have become pricey so in some cases swapping out the backing plates for a later Ford that you can get drums and shoes and hardware more readily might be in order.I was wondering where you were. Remember we had a discussion here previously about the conversion. You said one would either modify the retaining pin (2027 in Ill) or Modify the spring retainer (2028) by narrowing its' thickness I believe.
And now you are saying to find a later shoe(s) with later webbing that will accept the self-adjusting components. Makes sense to me. But if the FORD has 11" shoes and the MUST has 10" shoes, will the cable be long enough for the earlier shoe?
I just noticed you say your social group has a FAQ which I failed to notice. Is there more info there?
FORD actually began install "in 1958, but there is nothing in the MPC about it or the SHOP MANUAL(S). MERC has the info.
Anywho, I began to think (not common) that a front disc swap needs the rear self-adjusters to keep the drums in proper adjustment so as not to over work the disc.
THANX!
The TBirds used 11 inch shoes. There is a write up in the Early Bird magazine on self adjusting conversion with part numbers. I have a copy if your interested. Will send snail mail
This is a page from my '58 Edsel Service manual.
I don't know if nascardave is still active on the board or not but he would be a go to guy about info on front discs with stock parts. A very helpful guy. Don't know if he'll see this thread or not. You might try a PM also.
He has been a world of help on my '54 Ranch Wagon project.
What I am trying to do Paul is cleanly retrofit the 1965/67 KH 4-PISTON CALIPER design to early FORD/BIRD using all FORD parts.
Just wondering which way the poster went with his.
