1952-53 Ford throwout bearing with collar
Scott De Shields
Since I am running a late model Ford 4 speed with Jeep shifter on my new flathead can I run a late 50's thru 60's throwout bearing assembly with the stock stamped release arm? I am running a stock 10" long clutch. Don't want to run a NOS unit with a modified engine.
Thanks rotorwrench for the information. Found the answer to the throw out bearing question now have to deal with input shaft problem.
Hey Scott. You have a 40 Ford. Why not use the original type clutch release system?
Just wondering?
Jim
You might try Fort Wayne Clutch in Ft. Wayne , IN. They build and re-build a lot of antique and specialty clutches for cars, trucks, tractors, etc. Good folks who might have some ideas. FWIW.
