1951 Speedometer
Ogarland
Trying to remove speedometer out of my 51 Ford. I have everything disconnected except the mounting bracket at the top.I can't get the speedometer out from behind the bracket because of the screw coming thru the bracket. Is the screw a stud that comes out or is it part of the speedometer?
I figured it out. The screw is part of the casing that holds the speedometer. Take the nut off and the two on the sides and the speedometer will push forward. With all the lights and wires off the speedometer will come out the back of the dash.
