1951 Merc Brake Rebuild
captmidnight
New member
I'm looking for a complete brake rebuild kit for my 51 Merc coupe. Does anyone have any recommendations on where to buy one? I need shoes, springs, wheel cylinders for all 4 wheels and a master cylinder rebuild kit. The brake lines are fine.
Thanks.
Got new wheel cylinders for my 49 ford at napa for $8 apiece. All they had for shoes were the 11" station wagon. I got those at another supplier near me American Brake Hardware. $25 for a set no core needed.
As stated above components (eccept master cylinder) available from NAPA. You may want to consider installing self adjusters. All the components are the same as late 60's and up Ford F-100 pickup truck. The only modification that has to be done is to install an adjuster slot on the left side backer plates. The pic's show the self adjusters installed.
Thanks 51 merc. I was wondering if that could be done. If someone was doing their car for concourse I think you could put an access hole in the drum that would not show and allow you to get at the adjuster.
