1951 Ford F2 choak mounting location dash
raybakerjr
I have a 1951 Ford F2 which I recently purchased. It does not have a choke knob mounted on the dash and routed to the carburetor. I have purchased one and will install it.
My dash is stock. All holes are stock factory holes. So here is my question "which hole does the choke knob and cable assembly get mounted to?
The choke will be the hole on the right closest to the ignition switch. The hole on the left of the choke was the throttle cable hole.
