im getting in here late and some things have already been posted, but im going to go over them again, First, have a good battery with plenty of cranking amps, then 2nd is the right gauge cables for the voltage, as important as the battery, 3rd, clean solid connections, 4th, grounds and plenty of them, one from the battery to engine, do not use the exhaust manifold as a grounding point, a head bolt is the best, then to a bolt from the engine to a starter bolt , one from the engine to the frame, use another heavy cable for this, and one from the engine to the firewall, make sure all connections are clean, clean, clean and tight
