O oldsmerc Member Jan 16, 2014 #1 Can someone tell me if these boards fit earlier ford pickups? Thank you all for the information! Last edited: Jan 21, 2014
M Mike B Well-known member Jan 16, 2014 #2 I'm sure '48-52 are the same, but different from '47 earlier.
1952henry Well-known member Jan 17, 2014 #3 Mike B said: I'm sure '48-52 are the same, but different from '47 earlier. Click to expand... I agree. You would have to really modify the boards to get them to conform to the earlier rear fenders, front too, perhaps.
Barry-ct Well-known member Jan 17, 2014 #4 48-52 only without major modifacation. F-1 was all by itself and F-2 and F-3 were the same.
Fibber Mcgee Well-known member Jan 18, 2014 #5 They will fit 48 to 50 but the 48 to 50s are slightly different than the 51 52 under the cab.
Barry-ct Well-known member Jan 18, 2014 #6 The 48-50's have an area of metal that goes over the frame, the 51-52 only have a lip or rolled edge. They both have the notch for the cab corner. You can interchange them, but if you're going for points, you need the correct ones.
