1950 Tudor new front brake drums
Joe B.
If I want to install new front drums, is there a way to separate the drum from the hub, then install a new drum with new studs, with home tools? Nothing in the "Green Book" about this. I don't want to damage the hubs as they are hard to find. Thanks in advance.
591291
I haven't done '50 Ford drums but I've done lots of others over the years. I take a brass hammer and put it on top of the stud and then hit it with a big steel hammer, one or two hits and the stud comes out. Then put the hub in the new drum and hit the studs back in using a heavy steel punch, the sound will change when the studs are driven in all the way. I spread the hits out among the studs until they are all in to prevent warping the drum. It's just the same as if you had a broken stud and needed to replace it, except you pound then all out. Be careful so that you don't warp the new drum beating them back in.
Joe, can ytou post a closeup of one of the studs on the outside of the drum?
Joe, see the tack weld? Studs may already been replaced once.
I do not have a good close up after cleaning. But, I can not tell if there is any peening. Hence my original question.
Fordy, I examined the drums very closely after a thorough cleaning and see no tack welds or anything else.
My problem was a persistent pull left on braking. I tried adjusting, swapping, etc. until my face turned blue. The brakes looked good. So in August, I replaced the shoes (again), hardware, wheel cylinders and hoses, scuffed up the drums, which judging from the records I have are original, turned in the late 80's. Since then, the car is stopping straight, but it got me thinking about my original question. After lots of reading, I still don't have a definitive answer on the 1950's. Thanks for the links, Glenn.
591412
I think that from 1949 and later that Ford started using the modern, ridged type bolts, moving away from the swedged type. Searching this morning I was able to confirm this after looking at this very informative link from the "Model A Garage", https://www.fordgarage.com/pages/swaging.htm
This shows a removed swedge type. A hole saw or special cutting mill, cuts the part of the stud that is deformed to fit into the chamfered hole in the drum.
591422
This is how the installed, deformed shoulder of the swedge studs appear when installed.
591421
and here is a modern type, what you have.
591423
To remove your studs, you need to back up the hub on the inside with a large pipe that either goes inside the stud flanges or just outside of them. You could get by with a large deep socket and do them one by one as long as you can get a good stable flatform for the drum. Put a nut on the stud and use a BFH or press to push them out. Doing this prevents bending the hub.
I was just going to give you the same advice as Glenn. A 20 doesn't take up much more room nor costs a lot more.
