1950 Meteor power brakes
stegomo
As I am putting an electric fuel pump in would it be possible to use the mechanical pump and a vacuum canister to work the booster?
Originally it probably had a dual pump-- vacuum and fuel , if you have the original pump the vacuum section could be used without using the fuel section, the fuel pump alone won't make enough vacuum
As stated probably not enough vacuum. When I installed my booster I drilled and tapped a pipe thread ( any convenient location ) directly into the intake manifold.
