Joeyv
My 49 Mercury had a problem with the BW overdrive. When I would step on the gas pedal to engage the kick down switch, the engine would shut off. I used the manual I got from Fifth avenue garage to troubleshoot. I determined that the problem was probably a short in the solenoid. I sent the solenoid to Randy Gross, who repaired it. After that it worked fine. my 49 is setup with 12v. I’m not sure if Randy is still repairing overdrives, but his number is (714) 292-8660. I hope this helps. And BTW, I replaced the wiring harnesses with those I purchased from C&G old Ford parts. Good folks. Michael Driskell is in Tennessee and can probably provide the wiring too. Also good people.
