1950 main center cap needed
Dave1915
Rebuilding a flathead in a f1 did new valves spring n guides . Clean the gunk out figure drop the pan found a bolt . Got the pan down broken Cap trying to find another one Casting number on the cap is 7ra-6330 B
order a set of caps on line but different numbers have a feeling will not be the same any help be great
Dave
I kind of figure that I have the Tools to do if want go down that road. just wanted to find one that was close n have it with little bit of work. I have done it on tons of tractors in the past that still run today
