If you want the in-dash signal lites to work you will need the little sockets and bulbs. They are the same as ones in the back of the speedometer unit. Splice them straight into the wires going to the front or rear signal lites (after you install the above signal lite system). Most likely will need to swap out the front single filament lite socket for dual socket. Not that hard, really.
