MasonicMat
Welp, here I am.
I have a 1950 Ford Flathead V8 that will not start.
-Backstory: About a year ago bought the car ran great but had engine noise. Pulled engine & found main bearings & rod bearings were shot. Had engine machined Bored .60, line bored, holes for adjustable lifters, (the usual flathead stuff). The old timers at the machine shop are great and both knowledgeable and reputable with Flatheads. I assembled the engine myself using Mike Bishop's & Vern Tardel's " How to Rebuild & Modify Ford Flathead V8 Engines
I also installed a Schneider 270-F cam & adjustable lifter set. I adjusted them myself using Cheaterpeat 's timing indexer. Here is a link of what that is and how to use it. ( I used it as shown in this video ) https://www.youtube.com/watch?v=Joq_gSXfu6I
I also upgraded from 6volt to 12volt GM alternator style kit.
I added Offenhauser Aluminum heads
I added Offenhauser Dual Carb intake with 2 new Super 9-7's
Added 12volt frontside mounting starter.
...I think that is it....
-What I have done & know:
*I am cranking with enough speed to start.
*I have spark at all 8 plugs
*compression in each cylinder is about 115
*I am using firing order 154863721
*I set TDC with vac/pressure gauge (about 100 times)
*Tried flipping distributor 180 (a few times)
*Tried advancing & retarding distributor a few times back & forth in both positions.
*Tried positioning distributor 7-21 degrees advance increasing from 7.
*Adjusted carbs as indicated in instructions
*checked spark gap
*Thought it might be flooding. Left throttle open & removed plugs over night then tried again with just starting fluid....nope
Engine doesn't do much but puff & make a few sounds like it wants to start but no go.
It doesn't really backfire as I would expect from wildly set timing.
I am confused on what to do next.
I bought a spark tester to make sure the spark I see is good.
Do I need to have a flathead cam degreed???
Should I tear into it and redo the lifter adjustment even though I have good compression?
I need help!!! please help me!!
*checked spark gap
